1 - 4 of 4 Posts
oil coming out of back of pipe
is my rings starting to go or is do i need new packing in the silencer im running pro circuit pipe and r304 pipe ? any help would be appreciated
oil is starting to drip frequently when i ride and halve of my swingarm was soaked in oil
New packing will stop it for one summer. No, oil out the back doesn't mean you need new rings.
MX. Dad and Racer.
What mix raio you running ? 32 to 1 is your best choice
Carb adjustment done correctly [mixture screw]?
Good quality fuel 94 octane or better.
New packing will help.
A well tuned bike will have NO oil dripping out the silencer.
http://www.austinmx.com/the-ktm-guide.pdf
read the last couple pages of this it will help with how to adjust the mixture screw and carb set up etc .
good luck
thanks for the help, im running from 32 to 1 to 40 to 1 but usually 32 to 1, i measure it exactly with a mixure and use the gas pump at station to measure how much gas per litre. i usually run premium
1 - 4 of 4 Posts
