I have a prob wit my bike n dont know wat happened. looking for help if possible. somehow gas got into where the engine oil is supposed to be. i was trying to start it up n it would crank but it wont start so i looked at the oil area n it was flooded with gas. i then unscrewed the bolt to drain the oil and gas just started coming out like crazy. please help. this is my first bike i bought back in may
I would not try to start the bike again before you get it fixed.
You have a leaky carb and need to get it fixed. This would require removing the carb and cleaning it out, and testing it for leaks before reinstalling it.
Problem 2: IF you are running the gas petcock in "prime", move it to "on" or "reserve". Don't use prime until you get a clearer idea of what "prime" is, it should not be used regularly, I don't even use it at all, haven't for years. If you are in "on or "reserve", then the petcock is bad and needs to be repaired.
Drain the oil now and I would say not to replace it until the above are fixed.
Should solve your problem. Happened to me earlier this year.
