Hi everyone
I have a 97 KX 250 and ever since I've owned it it fouls plugs, even when ridden quite hard but worse when just playing around. A bit of background about the bike first. When I bought it it was in need of some tlc to say the least, so I spent an awful lot getting it into a rideable condition. I got fed up with the plug fouling so I stripped the carb and found both jets to be way off standard, it was also fitted with a V-force reed block. I then changed the jets back to standard, fitted an original reed block and reeds and dropped the needle right down, it still fouls and lags a bit when the throttle is opened, it take a few secs to pick up the revs when under load. Now one dealer says to me I should try running a hotter plug, while another says it's got nothing to do with the plug and that the problem lies somwhere in the pilot jetting system. I have dropped the mix to 40 to 1 and use a new filter each time. What do you guys think I should do to get it running spot on and save me a fortune in plugs.
P.S. I am racing it for the first time next week, so please hurry..!!!:lol:
