1 - 6 of 6 Posts
I have an 06 vulcan 2000. Stock air filter, and hard krome stripper pipes. I cannot find a map for my power commander for this setup. the closest i found was Vance and hines pipes with a stock air filter. Does anyone know where i can find a closer map, or should i just use the vance and hines map
Any help would be greatly appreciated.
Slow Guy on a Fast Bike
I'm not sure you will see any real benefit with the Power Commander until you replace that restrictive stock intake. Once you open up here lungs with a good aftermarket intake, then you will certainly see (and feel) a difference.
I found the best map I could find for my old V2K was from the ThundeR manufacturing site, I just tried a few until I settled on one that felt the best. Optimally, you would want to have a custom map made for your bike, with your specific set-up, tuned for the elevation you live in....but that can cost a fait chunk of change.
I'd recommend getting that aftermarket intake, removing the secondary intake butterflies (this can really "crisp" up the throttle response)....and finding a map that best fits your exhaust and intake from either the Power Commander site, the Thunder Mfg. site, or maybe someone here will have a map they can email you.
Deeppurple52
PCIII not needed for your configuration ands will do nothing for your performance.
Forgot to grow up
I was under the impression the fuel mgmt was used to cure popping when just pipes are changed. I kinda like the popping tho.
1 - 6 of 6 Posts
