I have a couple of questions, any input is appreciated
The closest table I can find for my 04 1500 Nomad is for Cobra exhaust and a stock air cleaner. I have Cobra exhaust and still have the stock air cleaner system with a K&N element installed. I'm courious if I should add a certain percentage to the fuel values to compensate for the K&N.
Also I noticed that the map I installed cuts back its up'ed values about 30% to 40% at the 40% throttle position. Example: The value is 22 at 2500rpm and 20% throttle but is 12 at 40% throttle. I'm curious how far up I can push the fuel in the 40% and above throttle positions. I want pleanty when for passing when running two up and loaded.
Thanks
Thanks
