powervalve and crankseals???
672 Views 5 Replies 5 Participants Last post by  dirtslinger76
whats the best way to check to see if your powervalve needs to be cleaned and if it does what the best to to clean it? Also how about crank seals how do you know if thier messed up is there a way of finding out without pulling the motor apart? Thanks for the help
1 - 6 of 6 Posts
leak down test
Powervalves - Take the head off and look (prob. new head gasket)(10 mins),
Seals - Leak-down-test (depends on exp.)
No need to remove the head to look at the powervalve. The cover on the front of the cylinder covers most of the working parts. If you can remove it without taking the motor out or cylinder off it can be done. But the down tubes are right there. Usually the powervalve is cleaned during a top end. You can use easy-off oven cleaner to clean the exhaust valve parts.
+1
Il give the powervalve a try thanks for the help I really appreciate it.
1 - 6 of 6 Posts
