1 - 2 of 2 Posts
Ok I’m new here. Looking for help on a prairie 360 4x4... it’s a 2004 I believe.. got it non running and had been sitting. Clean tank, replace fuel shut off and replaced carb... started right up and ran about a half a tank of gas. Then set for a few days and now it’s hard to start and once running it will not idle and cuts out if I can actually get it running. Thanks in advance for the help
Super Moderator
It does sound like carb issues. Did you replace fuel lines also? Sometimes the fuel lines start to break down internally and crap then flows into the carb. This happens faster when ethanol added fuels are used.
1 - 2 of 2 Posts
