Need help! Main wiring harness burned up. After replacing harness, the 360 will only run in limp mode or severely reduced throttle. Will not rev up!
Thanks, will give it a try and let you know what happens.QKENUF4U said:still missing wires or a component thats causeing a fualt code. either that or you need to reset the BRAIN BOX. look in your manual and see what it says about resetting the system.
