I have this same issue. I seen this was posted in beginning of 2020 and I'm wondering if you ever found the issueI have a 2008 mean streak 1600 it will rev at idle to 3000rpm when it warms up and it will not crank when it gets warm either any help would be greatly appreciated ?
hey so it’s a 05 mean streak. But it was my grandpas bike before he passed, when he had it, it ran and rode fine up until the rod bearings spun. I got a good deal on a classic motor unknown mileage and year. They are both 1600. This isn’t the first motor I’ve had to put in this thing since he’s passed. But this one has the idle issue. I’ve switched throttle bodies and still no results. It still runs after it gets warm it just revs up after it does get warmI'd say start a new thread but this ones that short you may as well carry on here.
We need loads more info before proffering an opinion on your issue.
That'll get the ball rolling.
- Age of Bike ?
- Mileage ?
- Servive History ?
- Any work carried out lately leading up to the proble you have ?
- Exactly what is happening ?
Oh and Welcome to the Forum![]()
Exact details of the above as it makes no sense how you wrote it.It still runs after it gets warm it just revs up after it does get warm
The idle is fine until it warms up the it raises to 2k. If I barely touch the idle knob it Dallas on its faceThe idle adjuster nob won't raise the idle?![]()
It does start after it’s warm. That’s not an issue. But how big does the air leak after to be to rev up that high.So it would seem that once the engine is warm, the idle shoots up to 3000 RPM. Sounds like a vacuum leak.
This would also explain why it won't start when it is warm (needs choke to add extra fuel to overcome lean condition from vacuum leak).
What I was trying to say the only issue is that it revs up after warm up. It will start after warming up.Exact details of the above as it makes no sense how you wrote it.
The leak can be invisible to the human eye. Testing is required. Although I just realized your bike has FI.But how big does the air leak after to be to rev up that high.
The map sensor hose was ripped off of it don’t know how must of been one of the times I pulled the tank or somethingSo it would seem that once the engine is warm, the idle shoots up to 3000 RPM. Sounds like a vacuum leak.
Don't keep us in suspense. When you re-connected the hose, did your idle go back to normal?The map sensor hose was ripped off of it don’t know how must of been one of the times I pulled the tank or something
Lol yes it went back to normal and ran a lot smoother also. But as soon as I went to go joy riding the throttle cable snapped so I can’t even enjoy it lolDon't keep us in suspense. When you re-connected the hose, did your idle go back to normal?
