re
welcome mark :wink:
i believe 2000 was the first year for fi on the 1500 classic
years 97 and up seem to be the best since all the bugs were worked out-not that there
were very many.
fi system is fine as far as i know
the bikes do not share the same frame specs-the frame tubes are larger as is the steering head assembly-other differences include higher compression motor which will require
premium grade fuel,about a 2hp increase over carbed model,ecu controls engine and can be re-mapped for intake/exhaust mods easily,holds about 1 gallon more gas than the carb bike
there are a few issues with certain aftermarket items that won't fit both models.
both bikes are great and its really a matter of personal preferance as to which one to choose
i like fi bikes and imo think you would be very happy with either one-they run great!!
here are the specs on the fi model - hope this helps - good luck :wink:
Engine type: 4-stroke V-Twin, SOHC, 8-valve
Displacement 1,470cc
Bore x Stroke: 102.0 x 90.0mm
Cooling: Liquid
Induction: Mitsubishi Digital Fuel Injection
with dual 36mm throttle bodies
Ignition: Digital with Throttle Responsive
Ignition Control (K-TRIC)
Transmission: 5-speed
Frame: High tensile steel, double cradle
Rake/trail: 32 degrees/6.4 in.
Suspension, front: 41mm hydraulic fork
Suspension, rear: Dual hydraulic shocks, 5-way preload
adjustable
Wheel travel, front: 5.9 in.
Wheel travel, rear: 3.7 in.
Tire, front: 130/90x16
Tire, rear: 150/80x16
Brakes, front/rear: Dual hydraulic disc/ Single disc
Overall length: 98.6 in.
Overall width: 39.2 in.
Overall height: 44.9 in.
Ground clearance: 4.9 in.
Seat height: 27.6 in.
Dry weight: 659 lbs
Fuel capacity: 5.0 gal.
Wheelbase: 65.6 in.
Color: Candy Cardinal Red/Pearl Gentry Gray,
Pearl Purplish Black Mica
