1 - 4 of 4 Posts
just cruzin by!
I have the phat II's on my bike and cant remember if the second hole in the bottom will move them up or back just a little.I used the center hole but there is one that an allen bolt can go in from the bottom.:confused:
T, the other hole that uses the allen bolt is toward the tank which will move the risers toward the headlight approximately 3/8"......I had to use these holes myself to clear the nacelle at full turn.....bikes will vary...STEVE
just cruzin by!
Thanks man! I dont have a problem clearing I just thought it would put the bars a little farther away from me.I should have went with the regular phatts instead of the II's
V2K Classic
I went with the regular Phats and glad I did, I had to reroute the clutch cable bit if it was any higher I would need new cables and wiring.
I used the allen bolt hole because the studs they furnished would not work with OEM nuts. I went to the hardware store and they wouldn't work with anything they had. I think that they were machined wrong from Scootworks.
I wonder if those tall risers with all the torque from wrestling the bike (when necessary) are structurally sound, or might they break like a reed in the wind..
1 - 4 of 4 Posts
