playing over in tortillia flats i bet ? :wink: just call up SR AXIS or BOBS and get another one.Aikata said:I was attempting to drag said peg around a corner and it broke off.![]()
Hehe, well I suppose the new pegs I ordered should help. After thinking about it for a while I wondered why it would be brittle enough to snap off. I guess it's not too common of a thing to happen.1Adam12 said:I scraped my pegs on the road - not intentionally, but on hard corners and the only time I've had one break off was when I crashed!
The pegs that I've ridden with had a tendency to fold back into the bike at about 45 degrees which would have prevented them from getting stuck with the ground on a hard turn.
Could be a chance to get a pair of nice adjustable aftermarket set.
Well, it didn't catapult me... it only snapped the bike upright instantly. Unfortunately I reacted with the standard "stoopid noob" freeze-up pose and forgot my bike had brakes or handlebars to steer with and ran off the road. It only snapped off a turn signal and scuffed up the opposite side of the fairing. I rode away with a bruised rib and a bunch of tiny itchy pieces of grass in my jacket. Can't wait to get those parts installed... it's kind of tiresome to ride with only one peg.ZX-2R said:Slight difference between dragging and breaking one off! Gees! Lucky you weren't hurt. If you get to the point where you don't want to do it then just hang your boot over the edge of the pedal...it WILL get your attention, and you may end up dragging a peg...hopefully not getting close enough to break one...that could actually catapault you...
Yeah, mine did too... it was still attatched to the removed peg... so I'm not sure if that was what caught on the pavement or not... the peg definately had some scratches on it too... :?:Edawg636 said:My 636 has replaceable "feelers" that screw into the peg. That way the peg itself doesn't actually hit the ground.
Unfortunately - that is personal practical experience and not someone elses. but on the bright side I get to share a neat little - didn't think about that one for someone else.ZX-2R said:Sounds like a veteran...I've done so much with so little, I can do almost anything with nothing. Sometimes a magazine works...Splint, funnel, short rest stop along the roadside, fire starter, insulation from cold, head exposure to the sun (hat), geeeeee.......
Just don't toss the bolt when you are done...you'll need it again for something else...or perhaps for the same thing, again...
Ok, but where do you put this bolt? The peg broke at the end that connects to the bike, meaning where the pin is attatched to the "rearset" or peg bracket. So, removing the peg was done when the breakage occurred, I simply picked up the pieces I could find and tossed them in a bag I had handy.1Adam12 said:Go down to your local Home Depot and buy a bolt to ride temp. Remove the footpeg completely and buy a bolt - probably 10mm or so and stick it in there until the real deal arrives. Better than letting your foot drag.
Good suggestion mikimoto!mikimoto said:I live in the mountains where there are twisties all around. Since my bike is lowered ('04 Zed750) I always allow the soles of my boots to scrape, as soon as I feel it, I hold that position thru the turn. I purposely don't want to drag the peg, I'm worried the pipe will hit and I'll high side.
Hmmm... great idea! Thanks for the tip... now I just will need to get a set of boots that are designed to scrapemikimoto said:I live in the mountains where there are twisties all around. Since my bike is lowered ('04 Zed750) I always allow the soles of my boots to scrape, as soon as I feel it, I hold that position thru the turn. I purposely don't want to drag the peg, I'm worried the pipe will hit and I'll high side.
Take your pick on one of the rear set bolts and replace it with a bolt from your hardware store - about 3 - 4" long.Aikata said:Hmmm... great idea! Thanks for the tip... now I just will need to get a set of boots that are designed to scrapemikimoto said:I live in the mountains where there are twisties all around. Since my bike is lowered ('04 Zed750) I always allow the soles of my boots to scrape, as soon as I feel it, I hold that position thru the turn. I purposely don't want to drag the peg, I'm worried the pipe will hit and I'll high side.
1Adam12 - Hey thanks... seems my pegs and bracket was backordered so I have to wait another week to ride with two pegs again.
