Ok,
Finally got the brakes working (mostly) and was able to get out on the road to test them yesterday. Decided to got north east because I really hadn't gone any distance that way yet. No real destination because I was leaving in afternoon and was really only supposed to be 'test riding' the brake and clutch line installations.
Hoped on the Green Damsel in same clothes I was wearing to bleed brakes and riding gear.
Riding for about twenty minutes, choosing roads in a kind of north then east then north pattern I ran into gravel after about 20 minutes. Can you believe I completely ran out of signal 20 minutes out of town??? So no GPS fix and no cell signal. I just kind of shrugged and decided to see how far the gravel ran.
It was only a short bit of gravel and I ended up on road 'of a sort' in about half a mile. It was road if you can call a bunch of patched pot holes all together a road. Seriously!
Then I got back on some actual smooth road and managed to get to the top of a hill to take my first GPS bearing of the ride. Turns out that GPS works fine from a hill...but the actual google map to go with it takes 5 minutes to load over one bar of edge. :^)
Right about here I noticed...dang...Sun going down.
So better make a decision and a plan. The map showed a conservation area a little ways ahead. I decided to get there and then cut back west to a major highway. Well, 10-15 minutes later and it was getting a bit chilly...I start to second guess my map usage and it turns out that I had the map zoomed WAY out. Oooops.
Picked another north to try to cut up to the county road sooner and found some great scenery. (Phone pics are close...but don't do justice at all.)
And the other side of the road....
Even had a farmer slow down to check on me because I was fiddling around with phone and picture settings. Good people there.
Another of the road, I love the off into distance pics.
(continued in next post...)
