1 - 6 of 6 Posts
Hi I have a 1985 kx 125 that runs strong and has good power but developed a rattling noise during deacceleration. The Clymer manuel says that it could be a connecting rod bearing. Does anybody know how I could check it without splitting the case? Any other ideas of what could be causing this? Any help is appreciated
Dirt Bike Dad
you can rip off the top end and check if there is any sideways play in the piston/conrod.
Could be classic decel detonation, bad gas or too lean in the cold weather. Get some fresh gas, if that doesn't stop it go up a size on the main to rule out this possibility. Wouldn't it be nice if this was the problem!
If you have a bad rod bearing you would hear rapping all the time, both acceleration and decelleration.
I think what you are hearing is the exhaust pipe vibrating against the cylinder. Check to see that there is a good copper crush gasket between the muffler and cylinder. Also check to see the exhaust to cylinder springs are there, and not broken or stretched..
I actually use 2 gaskets on my KX500 cause KX500 exhausts vibrate badly and will start to wear into the cylinder if left alone.
1 - 6 of 6 Posts
