1 - 9 of 9 Posts
RE: 95 zx6r - Strange clicking noise when set to RUN
When I turn my my key and then switch the bike to RUN it sounds as if the starter or something is just clicking constantly. It does it regardless of wheter I am trying to turn the bike over or not. Has anyone had this problem before? Any advise is greatly appreciated.
12/30 - The clicking is constant and appears to be coming from just under the back of the gas tank by the seat. The rattle appears to be coming from a rubber capped solenoid of some kind. Is this where the starter is? When I press the start buttun the bike turns over and runs but the clicking continues even while the bike is running.
I had that problem before but it was just the fuel pump presuring up.If the fuel was off it would keep ticking but when I would turn the fuel on it would stop once it got fuel and pressure.
AZ's Official Mechanic
i think its the fuel pump also but it should NOT TICK the whole time. it should pump up and stop making noise. might be that your fuel pressure regulator is wearing out.
1 - 9 of 9 Posts
