Did some reasearch. They are supposed to have some play because of the design of the calipers. They are called floating calipers.
A floating caliper (also called a "sliding caliper") moves with respect to the disc, along a line parallel to the axis of rotation of the disc; a piston on one side of the disc pushes the inner brake pad until it makes contact with the braking surface, then pulls the caliper body with the outer brake pad so pressure is applied to both sides of the disc.
watch this video and at 2:51 you will see how the caliper moves. Mystery solved:shock:
Video Library | Rocky Mountain ATV/MC
I guarantee it you press the brake lever down and you try to wiggle it the caliper will be rock solid.
