1 - 5 of 5 Posts
I have a 2008 Kawasaki Vulcan 900 classic I have done a major conversion to it added 5 inch extended bags and fender a tour pack and all sorts of other things we are in the process of trying to fix the rear suspension on it because with two passengers it does bottom out so we are stuck at trying to figure out what the factory spring rate is because we know whatever that rate is we need to go up does anyone have an idea on what the factory spring rate is for this bike
Progressive has a huge on line catalog. Might be interesting to see what they have listed for your bike. They may have more than one spring listed for it.
Discussion Starter #3
Apparently there is no aftermarket spring for my bike only the factory one which is fine cuz we're just going to make something work and modify another one to work my big question though is what the spring rate is for the factory one so I know that I need to go up from there but for some reason Kawasaki and no one I talk to can tell me what the spring rate is on the factory spring for my bike
Tbh I doubt very much you will source that information from any Kawasaki Dealer as it's not spec they are furnished with.
You may have some luck getting in touch with Showa and asking them.
This may be a starting point.
SHOWA
Hi
I have an 02 Vulcan classic. had the same problem of the rear tire scrubbing the fender, in fact Kawasaki ran the wiring to the tail lites right in the middle of the fender and the tire rubbed through the loom.My. you'll never get it to stop bottoming advice, throw the stock rear shock outYou'll never get it to stop bottoming out. progressive shocks is the way to go. A bit pricy but a precision piece of equiptment. Completely adjustable in many ways and rebuildable. I replaced the rear shock and rerouted the wire loom to run outside the rear fender under the fender rail and back into the fender near the tail light. I ride 2 up all the time. My wife is 115 lbs. could not stop the stock Kawasaki shock from bottoming. The progressive shock made the bike feel like riding a different bike. well worth the money. Hope this helps
1 - 5 of 5 Posts
