1 - 4 of 4 Posts
I recently wanted to change the tail light on my Vulcan 1995 800, I order one on eBay and it came with 3 wires brown green and green with a white line in it. I connect all the wires and the brake turns on. But when I press the rear or the front brake the light doesn’t do anything doesn’t get brighter. I check the switch nothing wrong there. What could be the problem. Is it the bulb wiring looks really good anyone have this problem before.
· Administrator
You need to figure out what your bulb socket wires correspond to. It looks like your supplier did not use Kawi colours.
Here is what your wiring should look like. The BL/R wire carries current when the front brake lever is pulled or rear brake pedal is pressed.
Rectangle Font Parallel Circle Pattern
1 - 4 of 4 Posts
