Ok, had to remove the stock pipes/exhaust to access a few things... having a hell of a time getting the **** thing back on... everything lines up except the bottom two bolts... it sits too high... if I take the rubber crush gaskets off the two top rear bolts between the exhaust and the bracket - everything lines up just fine, but I'm thinking those are there for a reason.. am I not torqueing down enough on those top rear bolts with the crush gaskets in place to line it up? I'm a bit nervous about just cracking down on the bolts hey. Any input would be helpful... luckily its winter, so I'm in no rush... Thanks!
