Hello Community,
this is my first post and i'm not a native speaker. So i would apologize if i can't explain things proper or if i use wrong words sometime, but i haven't found a good board in german...
What i want to ask is the following. (Searching the Board brought no matching result for me)
I bought a K&N replacement filter. I have already removed the black plastic cover of the airbox. Also i removed 2 screws, that hold the gas tank. This part, the gas tank is screwed to, is blocking the way to slip out the airfilter. There are 2 other screws that you can remove, so that you can remove this interfering part. I tried hard, but could't remove this screws, they are to tight.
Is there a trick to remove this screws? Would it be necessary to remove the whole tank? Or is there a other way that allows me to change the airfilter?
Thanks in advance
Peter
Thanks in advance
Peter
