1 - 5 of 5 Posts
I did some mods to my wiring harness that required removing some of the outer wrapping. Now I'm ready to wrap it back up, but I am not sure what kind of tape to use. I've been told not to use plastic electricians tape, as it reacts to heat and oils. I'm not looking for the split type loom stuff. Okay, then what is a good tape to use?
Posted this on KZR:
Dry Vinyl Tape From Tape Brothers
Duct Tape, glow tape, electrical tape, and tape products At Tapebrothers.com
Dry Vinyl Tapes are non-adhesive plasticized polyvinyl chloride film tape. Easy unwinding characteristics - tape clings firmly to it’s own backing for tight wrap. High elongation and good strength to permit trouble-free binding of wiring harnesses for the automotive industry. Dry vinyl tape also used for plating applications- high stretch, good “cling” characteristics and great conformability provide for superior masking in hard chrome and other plating applications.
DVT-76B 2 in. x 250 ft. Black Dry Vinyl Tape
Our Price: $6.54 Per Roll
Reproduction Wiring Harnesses for America's Muscle Cars
• Non-Adhesive Vinyl Harness Tape, made to the original mil-thickness.
• Just wrap it tightly around the wires and knot the end.
• 100 foot roll is enough to do 3 to 4 harnesses complete.
• Available in three different widths, as original.
• Correct for all years (1955 to Present).
Part # Description Price
R0058272 3/4" Vinyl Harness Tape, 100 foot roll $12.00
R0058276 1" Vinyl Harness Tape, 100 foot roll $13.00
R0067108 1-1/4" Vinyl Harness Tape, 100 foot roll $15.00
http://www.keefeperformance.com/silicone_tape.html
"36 Foot" roll of Self bonding silicone tape
High temperature silicone tape
This Mil-spec silicone tape is Rated up to 500+ degrees
Made of silicone rubber, this self fusing silicone tape will protect most all electrical wiring, connectors, hoses, spark plug boots and more from extremely high temperatures. The self vulcanizing process automatically begins when the two sides of the tape are put into contact. A catalyst on one side of the tape begins the bonding process as soon as wrapping takes place.
great for all electrical wiring, harness, cable, and hose applications
Colors: Red and Black
Exceeds MIL AA-59163 TYPE 1 & 2
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
Electrical, Home, Auto, Truck, RV, Marine, Motorcycle, Military, Commercial, Industrial, Generator
Norfolk,England
Expensive stuff. I didn't have that much to do, so I went ahead and used electricians tape. But thanks for the reply.
The point in using the tape that was recommended is that it is non-adhesive. Normal electrical tape will tend to unstick itself due to petrol vapours or heat, leaving a sticky mess. Dry or self amalgamating tape gives a much cleaner finish over time.
BACK ON TWO WHEELS
Posted this on KZR:
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
+1
1 - 5 of 5 Posts
