1 - 7 of 7 Posts
Hello all don't know if this is where this post goes but its good for now :)
I have a 2018 v-650 LT and i was wondering if anyone knows it the stems on the stock handlebar risers
unscrew or is it a bolt that the risers was molded over ?
Super Moderator
Kawi only sells it as one piece but I somehow doubt they would have tried to mold it as you suggested. Just my speculation but they may have used an interference fit on the threads in order to have what they consider to be a permanent assembly. It would be interesting to know if anyone has attempted to take these apart.
Super Moderator
Sounds like a great price and heck if you break one, you are not out a whole lot. Please post back here with your results.
The older Vulcans had a bolt that dropped into the riser from the top. 10mm If memory is correct.
I still have a bunch of adapter studs 1/2 USS (Harley riser) to 10mm if anyone needs some. Went through several different riser sets on my Nomad,,,
1 - 7 of 7 Posts
