My gas tank needs to be rubbed out and I'd like to know what is the best "stuff" to use. Is there a really good rubbing compound that will do the job?. Liquid or paste. If there is, what's the name. Haven't done this before so I could use some help. bruce
Obfuscation Engineer
Comet or Bon Ami with transmission fluid and a worn out scotch brite pad .
Can you tell I don't do body work ?
~kop
Depending on how much buffing the paint needs will determine the rubbing compound. You could probably get away with most liquid medium rubbing compounds. 3M is the only brand I've used, but I also get most of it free.
