1 - 9 of 9 Posts
just picked up a can of seafoam for my 1997 zx6. How much of it should i use on a tank of gas. Should i just go by the recommendation on the can of 1oz per gallon of gas or is more better? Just figured id ask.
Enjoy the journey!
Shucks/ O'Rlies auto stores in Eastern Washington state carry Sea Foam in a spray can.
You can also find it on the sea foam home page. Its listed as a new product.
Most boating supply stores and Wal-Mart carry Seafoam if you really want it. Berryman's B-12 I think works about the same as Seafoam but somewhat cheaper.
I ride what I like
I use either seafoam or Chevron Techron.
Go by recommended mixture. This stuff doesn't burn like gasoline.
If you want instant cleaning then pull a vac hose and let a little amount at a time be sucked in or get the aerosal can and spray down each carb. The engine will smoke a lot. Its just cleaning the crap out of the engine. Then pour the amount in the gas tank.
1 - 9 of 9 Posts
