1 - 2 of 2 Posts
I am looking for some input from all of the knowledge floating around in here. I have a 08 mean streak and I am looking for suggestions on what everyone found for a good setting. I am 190lbs and my wife is about 120. I find right now it is a little stiff for me, not real sure what it is set at either. I also have a stock seat currently and I'm sure if I upgrade that would soften the ride a bit? I just figure there are enough people in here that have been down this same road to offer some advise.
You are not sure of what number the shocks are set at now??? Try different settings to see what works best for you. Also adjust the air pressure which you may need to do especially if you are riding 2 up. Just be careful and use a bicycle shock pump to do it with. The manual should explain all of this for you and will probably give you some suggested settings as well.
1 - 2 of 2 Posts
