Hey everyone,
At my KLE 500 from 2006 I have 2 light beams (one - left short/city beam (SB) and the other long/ open road beam (LB)). The problem occures when I am using LB. When I turn on LB, LS is switched off and right in front of the motorcicle i ahave a gap of 10 meters when is no light. On the other hand when I flash, both SB and LB are turned on.
Do you think is possible to keep the SB turned on when I am using LB? If yes how can I do that?
Thank you!
P.S. I know that you don't put KLE as an enduro, but isn't a touring also.
Thank you!
