Show me the power, (wireing help)
626 Views 3 Replies 2 Participants Last post by  rbentnail
Can the wires to the brake light and running lights be tapped into under the seat and if so do you know the color code for the wires ?
2008 Nomad 1600.
1 - 4 of 4 Posts
I'm gonna assume that your 1600 is set up like my 1500.
When you take the seat off you will see 3 sets of wires running thru rubber grommets thru your reat fender. On the right side (right side when sitting on the bike) there will be 1 set of 2 wires. On the left there will be 2 sets- 1 set with 2 wires and one set with 3 wires.
The sets with 2 wires are for the turn signals. There will be 1 wire in each set that is the same color. This is the battery negative. On my bike this is a black wire with a yellow stripe. The other colored wire is the "hot" wire to the turn signal bulb.
The 3 wire set will also have a battery negative wire with the same color. The other 2 wires in this set are for running light and for brake light. 50/50. On my bike these are blue and red wires. Red for Running, Blue for Brake.
Hope this helps. What kind of mod you thinkin' about?
Want more lights on the back, I know when I see another bike in the dark from the back the little tail light just does not seem to be enough to wake people up. I had a set of red LEDs under my bags on the old bike and have an idea to do a little trick with flexable LEDs on my sissy bar. I am very picky and the install HAS to be clean.
I dont want to use any of the conversion kits that convert the turn signals etc. got to be differant. Will post pix when the job is finished.
Sounds like a plan. I did go with the run/brake/turn signal controller with clear lenses and colored bulbs. In the summer about 1/2 my riding time is after midnight. Well worth the time and money IMO.
1 - 4 of 4 Posts
