1 - 2 of 2 Posts
Is it wise to bypass the fuel pump relay? If so how do I do that?
The Mule runs for a while then stalls. Replaced the fuel pump, checked the vent. It's done this before and is a real pain in the butt.
no it's not wise. If the pump works at all, the relay is good. If you're dead set on bypassing it, it's easy but you'll have to figure out which wires to use, by reading the wiring diagram.
1 - 2 of 2 Posts
