Thanks much for the welding advice!! How about using heat to bend tubes? I have two 14" long rear vertical frame tubes (1" .125 wall mild steel) that I want to cut at one end, bend down about 4" and reweld. I was thinking maybe heat the still welded end and just push it down.
There's no room to use a bender this way and I don't want to kink the tubes, but if I use heat, will it weaken the bend area? This is part of a partial "konging" I'm doing to my KZ750. Below is a rough drawing of what I'm talking about.
