i have a 02 1500 vulcan classic and the clutch started to slip this spring. i know its a hyd clutch but was wondering if there is some way to adjust it or do i have to replace it right away. thanks
Probably the clutch is fine, but the spring is worn. Replace it with a Drifter spring.
You're 100% correct; my bad.Drifter spring?...........I thought the Mean Streak spring was the hot ticket? Correct me if I am wrong.
