Another freakin problem, my bike wants to slowly stall out when sitting at a stop after I have been running hard or at cruise. If I blip the throttle slightly it will continue to run and idle normal. Does not matter if engine temp is cold or hot. It pulls hard through all gears and all rpm testing, no flat spots at all. I have changed to larger main jet, new needles, larger pilot jet. Mixture screws are at 2 and 1/4 float height is 15mm. I'm thinking mixture to lean? Or float level low? One other thing I have noticed since new jet kit, my choke/fuel enricher circuit, does not have the same high idle that it use to have for my morning startup . Could their be any related problem?
All advice is welcome. I should be out riding!
