1 - 2 of 2 Posts
today for some reason when i pushed the starter it would just make a ticking near the lower part of the engine, sometimes it fires up and sometimes i just feel a little vibration and ticking noise . wtf. is it just a relay problem anyone got any ideas?
Sounds like a starter relay to me. As long as you know its not a dead battery. Does the engine start at a later time without charging the battery? Make sure the cable at the starter is tight. be careful, dont over tighten ti, you'll break the stud. Check battery connections, starter button and check to see that your getting current to the other side of the starter relay when you hit the start button.
1 - 2 of 2 Posts
