I have a Vulcan 900 custom and was thinking about replacing my spark plugs. Does anyone know what the torque and gap spec is on the spark plugs and what a good spark plug for the Vulcan is?
No. There is a spark plug tool in your toolkit that will bend and allow you to get these out without removing the tank. If you do not have this tool, you probably would need to remove the tank.How complicated of a procedure is this? Do you have to remove the gas tank?
I use a regular plug socket with a 4 inch extension. I put that down in the front cylinder first then attach the socket wrench.How complicated of a procedure is this? Do you have to remove the gas tank?
This is not ment to offend you so please dont be offended, its just good solid advice.I'm about to change plugs on my 900.. Any pics how to use that "tool" that we have with bike, so that we don't need to remove tank?.. or maybe just pic of that tool?..
Ok, all I wanted to ask using my poor english (sorry) is - is the tank removal for the rear plug necesary?.. thanxThis is not ment to offend you so please dont be offended, its just good solid advice.
if you cant pick out a spark plug socket out of a 10-12 tool kit that comes with the bike, or once you find said tool you need instructions on how to use it you shouldnt be considering replacing the plugs on your bike yourself.
Not with that toolOk, all I wanted to ask using my poor english (sorry) is - is the tank removal for the rear plug necesary?.. thanx
thanx.Not with that tool
I just changed mine out and used NGK CPR7EAIX-9 you can get them at SPARKPLUGS.COM same plug as OEM but with iridium tip, little pricey but a much smoother ride and well worth the price, they come pregaped at .035.I have a Vulcan 900 custom and was thinking about replacing my spark plugs. Does anyone know what the torque and gap spec is on the spark plugs and what a good spark plug for the Vulcan is?
