1 - 2 of 2 Posts
Bad squeek in a Vulcan2000 Seems to be coming from the rear. 4800 miles on the bike. Does it from 3rd. gear on under a light to moderate throttle. Stops when the clutch is released. Only starts after bike is warmed up. Takes about 7 miles to warm it up. I've heard rumors about bad rear wheel bearings. I was told that bearings weren't covered under warrenty. Any help would be appreciated. Drace
AZ's Official Mechanic
so does it do with the clutch OUT or PULLED IN ? if it goes away with messing with the clutch then i would say it has to do with the clutch basket or similar part within the clutch pack.
1 - 2 of 2 Posts
