NOT STARTING
suction all the gas out into a gas can and get fresh gas...make sure that you work the shut off valve several times, check the OFF swith on the bars...work it a couple of times and...slosh the gas around when you put a fresh gallon in it...pull the plugs check for spark and while they are pulled pull the choke fully on and the throttle WIDE OPEN and crank it over to clear out the carbs...hey and any old air (HA) in the cylinders, then reinstall the plugs and try to start it without the choke first. IF the bike is not turning over fast enough...you may not be getting all the spark that you need to start it..you CAN use jumpercables (carefully) and get a full spark through the system. IF you have altready been cranking on it without it starting you should probably clean the old plugs with alcohol while you have them out, or for the price just install new ones. Let us know...next time you want to store the bike for several weeks use some STABLE. or gas stabilizer in your tank and drive it around the hood before you park it again so that it is all teh way throughout the fuel system...before you park it... LET US KNOW!!!
