I did install the AllBalls tapered bearing setup in the 1978 KZ1000a. As far a photos, I didn't get many. After pulling the upper and lower triple trees, I used a long copper tube to knock the top race out. It popped right out - too easy. The bottom one however didn't want to come out. I ended up using a 2 lb. solid iron "chisel end" prybar to get it out. It took 1/2 an hour of careful controlled dropping of the iron pry bar (chisel end) onto the lower race that was protruding into the neck space. It finally relented. Installing the upper race went in fairly easily with some nudging from a plastic hammer. The lower one was a bit harder. Finally, I heated (not too hot) the inner side of the neck tube - coated the inside with grease, and used a socket of the same size to send the race to it's home position. The lower taper bearing needed to be pressed on to the lower triple tree shaft. I used the old "ball race, which would bear down on the inner collar of the new bearing - and not against the roller bearings or cage"" to drive the new tapered rollers down to the bottom of the triple tree shaft. I used an, "I think: 1.5" piece of pipe to slide hammer against the old race to seat the new one. I then greased the upper and lower bearing and race with marine grease, and reinstalled the triple tree - then torqued.
