So I'm replacing the starter relay on my 94 ninja 250 because it wasn't starting when I hit the button. So I change the 85 dollar part still nothing when I hit the button. OK now I'm a little po'd! Screw it I will hook up the brake lights get them working. So I get the rear light hooked up works good no problem. Go to the front pull the switch off the bottem of the lever, start monkeying around with stuff, trying to figure it out, step on the rear brake to make sure the light still works and yep the **** thing starts up I about wet myself laughing at it! So three hours later after messing around with the six pin plug I got it figured out. Just thought you guy's would get a kick out of this.
