I had a shop make me up some struts for the back of my KZ750. They made them from 1-1/2" by 3/4" mild steel bar. I noticed after I picked them up that the bottom (swingarm) hole is sort of near the end of the bar, with about 3/16" steel at the end, like in the attachment.
I know that is more steel then is in most shock eyelets, but is that going to be strong enough? All that area has to do is lift up the wheel/swingarm if the frame gets higher off the road in a bounce, maybe 50lbs total on each bar. I think it will be fine. Anyone disagree?
