What size are the studs, where'd you get them, and any special tools required?
I'd like to add some concho's and fringe to my plain Saddlemen's this winter.
I use 3/8"th's 1/2" and 11/16th's" studs
You can buy studs from cycle parts stores, saddlery shops, or leather crafts shops. The most common size that I use, and that are used on most saddle bags that you can purchace are the 1/2" size. I have a tool (punch) that I use when I can lay the leather out and place a piece of pine board underneath. Lots of times this can't be done. When you can't, then I use a
12" ruler, ball point pen, a "sharp" razor blade knife, a stud, and a common screw driver. First, find where you want to place your first stud, and with the pen make a small dot to mark the spot. Now, grasp a stud with your thumb and pointer finger and with the two prongs facing down, press lightly on the leather with the prongs being placed evenly on both sides of the dot. (leaving an impression) Now, take the point of your razor blade knife and place on the left or right side where you made the impression, and carefully
while applying pressure move the blade up and down until you feel it cut through (this is the critical part) be sure to cut only the desired amount, or you will see the cut if you go alittle to far. With time and practice, you will get the knack of it. At times you will slip and cut alittle longer than you wanted to, but if you do all is not lost, the stud will still stay in place but you will see the cut somewhat. After inserting the studs in the slits, turn over and take a screw driver and bend back the prongs. Be sure to get the tip of the screw driver on the very end of the prongs and with enough forse you will be able to push it deep into the leather. When done properly, you can move your hand back and forth and should never get it snagged on a prong tip. After the first stud, decide how far apart you want them. On most jobs, I like them spaced 1" apart. Each time, use your ruler to measure the distance you desire. When you measure (say you want 1 inch apart) hold the end of the ruler in the middle of the stud, and mark your next hole with the pen on the start of the 2" mark.
Practice on some leather until you get use to it, then go for the real thing.
Good Luck!!
