After putting this off since i got the bike last year I finally got the courage to deal with this broken stud issue on the front pipe front bolt. Ive had a bad carb fart issue right when i open the throttle since I got the bike and I think this couldnt be helping any. Everything else I have tried has failed to solve the farts. Im also Grampsizing this week as the parts slowly trickle in which is reported to help farting as well.
I dremeled the stud flush to the head then, using Carbide drill bits, slowly drilled through the bolt. This would have been impossible without those bits, everything else was too soft. The drill started walking slowly towards the left a little at the end causing the hole to be slightly off center but it wasnt so bad that the exhaust didnt mount up. I put a M8 Heli-Coil in there and threw the exhaust back on today, job done!
