1 - 4 of 4 Posts
900 RedCustomRider
I have a VN900 Custom and want to install a tank bib. Does anyone know how the plastic shroud around the gas tank gauges comes off. I removed the one visible screw in the back. How it is still fastened underneath in the front?
hmmm its been awhile since I had mine off but I think there is just the one screw at the rear ( nearest to the tank ) and then you slide the shroud forward. I believe there are 2 rubber grommets at the front of the tank that the shroud slides into. Take a carefull look before you do it because I can't be 100% sure but that seems to ring a bell with me.
900 RedCustomRider
Discussion Starter #3
I was afraid for braking it seeing it’s only plastic but you are right on ScooterDude. Taking your advise, I pulled the shroud forward and it popped right of. Thanks.
1 - 4 of 4 Posts
