1 - 2 of 2 Posts
If it is a mono shock like my 04 800 classic was, you can remover your front sprocket cover and then use a large standard screwdriver to adjust the settings. Get a flashlight and look inside when you get the cover off and you'll see what I mean. Use a large hammer to hit the end of the screwdriver which you have up against the tabs on the adjustment ring on the shock.
Clear as mud? Hope this helps.
1 - 2 of 2 Posts
