Also please describe when throttle cuts out. Is it just off idle, midrange, wide open, while parked and revving engine or while on highway. All of this will help us try to help you figure this out.
It's an 07 Z1000. when I bought the bike,I quickly found and out that the gas tank was full of rust. So I resealed it and and it was fine for a couple of days, then it started to backfire a lot, it has an aftermarket exhaust that makes it a single exhaust. It cuts out as soon as you twist the throttle, but if you ease into the throttle it slowly revs but with a lot if sputtering. I was able to listen to the injectors ,all but one sound good. Right now I have put a lot of Lucas fuel injector cleaner with a little marvel mystery oil and trying to see if it will clean itself out.
Related Threads
2.3M posts
133.7K members
Since 2003
