1 - 11 of 11 Posts
I installed module today on a 2002 1500cc Meanstreak and need some help. I can't figure out what color the injector wires are. It is hooked up to grey and blue wires that I thought were injector wires. My VTX buddy and I worked on it and we started it up, but the green light flashs, which indicates there is a problem. The connections are good. (Those HK pipes are very loud) Now I am not sure that the wires we tied into are even part of the ECU. I don't have an electrical diagram. Called the local Kaw shop and was told to look for Blue/red for front cylinder and Blue/green for rear cylinder. I can't find any wires those colors. Any help would be appreciated. Thanks
Thanks Whistle, I knew I should have ordered the repair manual when I saw the thread you had about that. I will call when Thunder Tech when they are open. I think it was flynsouth who has about the same set up. I emailed him and have not heard back.
Brian, your dealer is right those are the right colors. (If you look at the map from TFI it shows those wires colors under "Injector" but I also have the manual and checked it out) When I put on my TFI I did the intake at the same time so had the tank off and connected right at the injector connector since to be honest I couldn't find them buried in the harness. I'd suggest that may be the easiest thing to do.
I have the same setup and it runs great so drop me an email if you have any questions
Flynsouth, Thanks, I was being lazy and should have taken the tank off. I thought I had the correct wires, but obviously not. I did send you an email to see what you set the pots at.
Look for my email, it's got the link to the Techlusion website and Support Forum that I pulled them from. In case there's a problem or for others here's the homepage, click on Support forums and you'll see what you need.
http://www.techlusion.com/
That did the trick I found the ECU and i think I have the wires now. Thanks for the help
Man I love this place! :)
I have a 03 Vulcan 1600 Classic that has a Thunder mfg Lightning II installed. It was on there when I bought the bike used. I cannot find any tech manuals or instructions on adjusting 4 screws on it or how they should be adjusted and even what the box does. Tried multiple searches on it with now luck. Anybody have any info? Thanks,
Super Moderator
Thunder went out of business around 2017 I think. Hopefully a kindly member who has a manual will send you a copy.
I think the box is wired into your FI and can adjust flow rates.
1 - 11 of 11 Posts
