Maybe run some "Sea-Foam" in the oil to clean up anything that may be clogging the automatic tensioner. Cam Chain problems, especially when cold could cause a cam chain jump, and that leads to catastrophic failure. Most of those units unbolt from the engine and can be checked. You would have to own the factory manual to know this. That's not a lot of miles on a big bore bike. If it goes away when the bike is warm, don't take off with it cold. Sea-Foam works wonders, use only the amount recommended. If it's possible to remove the tensioner, and it just costs a gasket re remount it, might be worth it. A lot of vehicles make strange noises when they start, and frankly, if it goes away, maybe why bother.
I have a lot of experience of Mercedes Benz V-8 engines. When they clack when cold. you shut off the motor and immediately change the tensioners, as they are "gunked up" and one day soon, it starts, jumps the cam chain, and bends all the valves. Speaking from experience here. I let someone else adjust the valves once after back surgery, and he broke the oil tube the feeds the cam towers, which seized the overhead cam chain, and I lost the motor, it was a 1975 450SLC. Can't go into what happened afterwards, but he suffered for that error. Point is, only you know your bike, and the sounds tht may just be parts of it's waking up process.
You have to decide how hard to go into it. Get the "Factory Manual", it is a must for a bike you intend to keep.
