1 - 5 of 5 Posts
I have an 02 meany with D220 tires.
I am in the process of replacing my
second tire.
The first one started cupping at 3,000 miles.
The second one which was just mounted and
has 550 miles make a noise like a banshee over
45 mph.
That one is being replaced.
Is it just bad tires, or do I have a front fork problem/
Say wheel bearings?
Any thoughts, suggestions?
Thanks,
MOF
re
i'm assuming you kept a close eye on air pressure and they were
balanced :?:
bikeaholic is right, air pressure and balancing are a lot more critical on a bike than a car. I check my tire pressure before every ride. believe it or not 2lbs. of pressure makes a big difference on tire wear.
Tire noise
The other guys are right about tire pressure. I don't think tires shuld sing or hum or souund like raving banshees. A good tire will ware well and long if it the right one for your style. Do some research and find the maker of tire that suits you. :lol: Check on line for different stickiness and hardness. Maybe you are just hearing the rubber come off on the road, like money down the drain. I do not like Bridgestone but if you did a survey you would find as many different tires used as guys listing em, so talk and research is the way to save your tires and mone.
1 - 5 of 5 Posts
