I have a VN900 with 20K Kilometers. On a recent ride my bike engine started to rattle. It doesnt do it at idle but only when you rev it up. I figured it must be a rocker problem as I thought the noise was coming from the rear cylinder. I have removed the rear head cover and checked the shim clearance. Funny thing is when i set the crank at TDC for the "R" rear cylinder , I cannot get a feeler gauge between the shim and rocker. When I set the crank at TDC for the "F" front cylinder I have clearance at the rear rockers, but barely .010 . Am I doing something wrong?
Help.
Help.
