Does anyone know if you need to set your tps to factory after installing a fuel programer? I did not and my fuel mileage has not been real great but my plugs look good. Maybe my right hand has been enjoying the power. 03 1600 classic caddmann gutted pipes and tfi
Nobody Home
Adjusting the TPS will give across the board richer or leaner. TFI will allow richening in general areas, part throttle or full throttle.
Life Begins at 200 mph
The TPS should not be touched. Whatever it was stock it should stay in that position. When you add a fuel processor, that is where you make the adjustments. Otherwise you are just being couter productive and wasting time.
If you have the money, I recommend a Power Commander over the other fuel processors due to the adjustability. I also have my bikes dyno tuned after making the Big 3 changes so I get the optimum perfomance out of them.
