1 - 6 of 6 Posts
Does anyone have any "best practices" for removing the rear ignition coil on a Mule 3010 (KAF620E)? My rear cylinder is not firing and the rear ignition coil's secondary wiring reading is showing "open". The manual says to remove the torque convertor and then the starter, seems like a LOT of work to replace a coil. :shock:
Does anyone know any tricks or shortcuts for this procedure? Also, where is the best place to order parts?
Also, I noticed in this forum as well as others I belong to that a lot of people do not follow-up with their findings when a problem is resolved. I will try to do my best not to fall in that rut. As you can probably tell this is my first Mule and she is a HIGH mileage animal that lived its whole life pulling duty in an RV park.
Many thanks,
Baxter
Greenwell Springs, LA
Just follow the manual's instructions.
8mm wrench and a 1/4" drive short 8mm socket on a 1/4" ratchet. It helps to have small hands, a "gift" which I personally do not posess. I've done a few lately and while they're not the hardest job I've done, they're also not the easiest.
An 8mm ratchet wrench is probably the easiest way, but you need patience as you can only turn it a small amount at a time and starting the bolt back in can be tedious.
just to update. I found this forum when I was trying to replace the exact same piece. I went to autozone and bought a 5/16 flex-head ratcheting head set. Worked perfect. It was a pain in the butt, but it did it. postIng this for the next Joe blow who has to deal with this. Best of luck brothers
1 - 6 of 6 Posts
