1 - 7 of 7 Posts
1999 Mule 2510 my left rear axle has play in it a little over an inch. it can slide in and out. Are there C clips that may have failed or not been installed when my mechanic replaced a broken axle? Please advise, Im deep in the woods and need this thing to haul my winter wood.
Thanks
where is the play? If the inner axle slides an inch out of the transmission/gearbox, then yes, there is likely a missing clip. If it is sliding on the outer axle, into and out of the hub an inch, the nut is missing or they forgot a bearing or spacer.
Discussion Starter #3
When I pull on the axle or hub while connected, the axle slides out but stops. Looking at the axle while I do pull on it I see the boot expand. It stops there and does not go to the next part of the drive shaft/universal into the transfer case.
looking closer, I noticed that when I push it all the way in the inside of the hub rubs up against the guts of the brakes and wheel/ brake cylinder. So the axle seems to go in to far!
The last time this was apart was for a snapped axle closer to the gear box.
Take it apart and see what's missing or broken.
the hub should never contact the wheel cylinder. If it does, you may have a bearing failing, or a spacer missing, or whatever. Only way to know is disassembly.
Inner axle should be tight in the gearcase, should NOT move in/out at all. There is a circlip on the back of the flange that keeps the axle from sliding out. If it's moving in/out of the gearcase, the clip is missing/broken/etc. Again exploratory surgery is the way to find it.
And as a reminder the center of the axle, there is a male and female spline. That sliding spline has to be free, once they get rusty and bind, bad $tuff happen$. That is actually a service item. I like to use some spray chain grease, use a pick to pry the boot up a little, stuff the spray grease straw into the boot and spray it for a few seconds. I have seen lots of them stuck and I have seen lots of them twist the axle off among other things.
Partzilla parts diagrams can be of great help in determining if parts are missing. There are 6 versions of the 2510 parts diagrams A1 to A6. Here is a link.
Discussion Starter #7
Ok thank you. The inner axle does not move in and out. Just the outside to the inner!
1 - 7 of 7 Posts
